Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/Anyone rebuild their hydraulic valve lifters?
Imported from Z31Performance.com Forums{{#if:spddm0n| — original post by spddm0n}}{{#if:2017-07-02 03:32:58|, posted 2017-07-02 03:32:58}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/536235-anyone-rebuild-their-hydraulic-valve-lifters.html|
spddm0n: (2017-07-02 03:32:58)
This discussion came up in a discussion I was having on the Frontier forum, and I'm wondering if any of you guys are rebuilding (cleaning, inspecting, and refilling) your valve lifters. I'm building several of these VG motors right now, and it isn't cost effective to by new valve lifters for each engine, each time. Some of my heads only have about 50K-65K miles on them, and likely no reason to bother with addressing the lifters, but other heads have 150K-200K miles and it was noted that the lifters begin to get sticky.
I began wondering what makes them "sticky" in the first place. Could it be that the oil inside them (certainly below the check-valve assembly) could be old and gunky (due to not cycling out regularly), and thus opening them up, cleaning them, and replacing the oil with new oil would refresh the lifter for another 150K-200K miles?
What are your thoughts/experiences?
spddm0n: (2017-07-02 03:40:53)
Here is a link to the page on ZenonCar.com where it is explained how to clean them.
https://dev.z31library.com/xenonzcar_archive/z31/RebuildingLifters.html
Z_Karma: (2017-07-02 15:30:30)
I figure if they have enough miles on them to be gunked up and are at all in question, pull some from a junkyard motor,
out of a low mileage Quest (that's what we did for a friends 86na) Inspect them for wear and toss any that look questionable.
I had a few that the springs seemed a bit more compressed when compared to others but they seem to be quiet enough.
I soaked mine in ATF for about a week before rebuilding as per the link (wasn't in a rush) it didn't seem to attack the gunk inside.
I then cleaned them in a heated ultrasonic bath (similar to this) using a 1:1 water/Krud Kutter solution before assembly.
That did it. They then sat for another week or five submerged in 5W30 before installation. Not difficult, just time consuming.
daniel_pearce: (2017-07-03 01:36:23)
As far as I knew, they're self adjusting hydraulic valve lifters so they didn't need as much maintenance and tuning after the P90 from the 280ZX in 1982. I don't even think you can get new ones from Nissan anymore. Many of their parts are NLA. The valves, upper cylinder, and intake manifold tends to get very dirty and gummed up in these VG30E engines. Don't bother using fuel system treatment products like Lucas Upper Cylinder Treatment or Techron Fuel System Cleaner. You need to use it faithfully about five times in a row to see even minor results. Even then, there's still carbon deposits on the cylinder heads. The only one I've ever known to make a difference was the BG 44K Fuel System Cleaner.
Z_Karma: (2017-07-03 06:30:25)
{{#if:daniel_pearce|daniel_pearce wrote:|Quote:}}
[archived image: 0mw1I8e.gif]
https://www.nissanparts.cc/oem-parts…ers-13231v5005
13231-V5014 Superseded to 13231-V5005 12/01/1985 to 07/03/2018
daniel_pearce: (2017-07-03 16:41:48)
Ah, but here's the thing. I've placed parts in the cart before from wholesale websites then paid for the order. A day or so later I'd get a message from the local dealer saying we're refunding you for your order because the part has been discontinued. I would always double check with the dealer first before ordering to make sure they have them.
Timbo_021: (2017-07-04 09:48:08)
Baha, shut down.. [archived image: wink.png]. I've rebuilt a set before. Takes a looong time but no dramas afterwards. Just need to make sure there is no major physical damage or wear when you inspect them. And make sure you don't lose any of them jesus clips that hold them together! Most of the time it's carbon in the one way valve that makes them leak down.
spddm0n: (2017-07-07 22:48:00)
I successfully broke down two sets (two engines), and even the low mileage JDM engine lifters were really gross. In fact, they gave me more trouble than the USDM engine from a 2000 Xterra. I suspect oil maintenance in Japan is bad to begin with, since they don't register the vehicles after 100Km anyway - I imagine the owners are less likely to worry about regular oil changes. [archived image: smile.png]
The most important tool happened to be a 3/8" cylinder brush that could get down inside the lifer body. Cleaners are no replacement for the ability to scrub. [archived image: smile.png] I did also find a couple with bad check-valve assemblies (the ball on the spring at the bottom of the inside). It might have been due to the little pick I used to reach in and pull up the check-valve. The old gunky oil was so bad (even after soaking in cleaner) that I could not work the check-valve out without assistance pulling up on it. You have to depress the ball down on the spring and pull at the same time. I have some extras from another engine that look good.
I started to reassemble them. Takes a bit more time assembling them. Using fresh 10w-30 oil. That oil must not cycle out as fast as the rest of the engine oil in other places. It's pretty nasty in there. This is probably the best way I can see getting a visual on WHY it is important to change your oil regularly. [archived image: smile.png]
