Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/1985 300zx power gains
Imported from Z31Performance.com Forums{{#if:Eric9006| — original post by Eric9006}}{{#if:2014-08-18 17:25:50|, posted 2014-08-18 17:25:50}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/24180-1985-300zx-power-gains.html|
Eric9006: (2014-08-18 17:25:50)
I currently have a 1985 300zx NA 5 speed. I'm wanting to add a t25 turbo for now til I can build bottom end and do a t3 turbo. I'm wanting to know what I will need for the t25 turbo swap and what other minor mods can I do without pushing the stock clutch limit. Thanks in advance
les_joey_paul: (2014-08-18 17:43:24)
I did t3 swap stock clutch is still holding up fine
Eric9006: (2014-08-18 22:38:40)
Did you go from NA?
les_joey_paul: (2014-08-19 01:35:18)
Yes. I did.
Eric9006: (2014-08-19 21:45:33)
what psi are you running? any other mods? what type of dyno numbers do you think you are hitting?
