Forums/Z31P/z31-performance-upgrade-forums engine-management/stupid retard question of the day
Imported from Z31Performance.com Forums{{#if:jjewell| — original post by jjewell}}{{#if:2006-07-03 19:16:17|, posted 2006-07-03 19:16:17}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/324-stupid-retard-question-of-the-day.html|
jjewell: (2006-07-03 19:16:17)
when adjusting base timing if you set it at 20 degrees would 10 degrees be advanced or retarded ? not that i would set it at 10 degrees i'm just using that as reference. 0 degrees is the first line to the left on the pulley with every line being 5 degrees currect?
Stinky: (2006-07-03 22:09:05)
10 degrees would be retarded compared to 20 degrees. Basically…
Higher number = advanced
Lower number = retarded
jjewell: (2006-07-03 23:58:17)
thats what i thought . someone told me different today and i had a huge freakin brain fart.
Jason84NA2T: (2006-07-04 02:52:27)
think about it in degrees BEFORE top dead center (0) and it makes sense. Yes, each mark is 5 degrees on our balancers.
