Forums/Z31P/z31-performance-upgrade-forums engine-management/stock z31 tables
Imported from Z31Performance.com Forums{{#if:kairamiel| — original post by kairamiel}}{{#if:2014-06-20 21:24:27|, posted 2014-06-20 21:24:27}}{{#if:10| · 10 post{{#ifeq:10|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/23910-stock-z31-tables.html|
kairamiel: (2014-06-20 21:24:27)
Will somebody post a screenshot of the fuel and ignition tables from the stock z31 ecus? I am tuning my engine from scratch with a haltech sprint 500 and would like to have stock tables, preferrably na and turbo to reference from. Fuel and ignition please! Thanks, if possible!
slammedfc: (2014-06-21 01:31:07)
If you get a pm or an email consider yourself lucky. I've been tuning my stand alone from scratch. Props to you for putting a vg into an fc. Most people do not want to post maps because they dont want to be held responsible for user error, acts of god, etc.... maps from a stock na and both variants of turbo block compression would have helped me out with months of hard work out on the street meticulously tuning my car. It's a pain in the ass doing it that way… I'm still very apprehensive to share my maps with anyone. It's not about the money, it's about keepign people safe and i swear if i had those maps i'd open source the hell out of them to do just that.
kairamiel: (2014-06-22 20:30:30)
I was hoping it wouldnt be a big deal. I see people posting stock nistune bins all around, but i cant actually see the tables. Can i download nistune and open up the tables to view them on my own? Or does nistune only work if you have a nissan ecu plugged into it. I know the load scales are different, but im confident i will be able to get a start from there. Fuel tables are simpler because you have 02 feedback and an engine can operate under a fairly wide afr range. My most difficult area is ignition timing maps, Creating one from scratch with absolutely no references. Maybe someone can throw me a tip or two on ignition timing theory?
Rustspecs13: (2014-06-23 12:56:37)
You should be able to download nistune and use it as a trial and view anything you want that way.
If guys can't find I can screen shot my laptop later tonight.
~Alex
kairamiel: (2014-06-23 20:25:57)
Ah, well in that case ill do that. Thanks guys!
Big Slappy Z: (2014-06-24 14:05:04)
Let me know if that doesn't work. I should be able to load it in my software if I can find it.
slammedfc: (2014-08-14 03:07:10)
Apparently we need a timing map sharing thread. At least if someone has a timing map they can just start pig rich then start tuning from there. I can't see that going over well though....
Silli: (2014-10-25 22:16:11)
VG30ET eurospec
For your eyes only [archived image: smile.png]… seems that forum is chewing out the picture..
slammedfc: (2015-02-14 03:04:48)
Just curious. What's the left to right top row values scaled from? Can't be kpa or psi.....
jaqattack02: (2015-02-15 04:45:14)
{{#if:slammedfc|slammedfc wrote:|Quote:}}
That's the TP scale, aka Load Scale.
