Forums/Z31P/z31-performance-upgrade-forums engine-management/fuel injector upgrade
Imported from Z31Performance.com Forums{{#if:Lance| — original post by Lance}}{{#if:2006-12-30 23:16:56|, posted 2006-12-30 23:16:56}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/1387-fuel-injector-upgrade.html|
Lance: (2006-12-30 23:16:56)
inside the 'top hat' on the stock fuel setup; http://www.redz31.com/images/fuel/injectors3.jpg
it seems as though I still have some fuel hose inside it, preventing it from coming off. What should I do?
Lance: (2006-12-31 01:19:30)
that trash. yeah. fire perhaps?
matthunter1448: (2006-12-31 03:42:24)
i just did mine i used my knife and cut all the way down then took some pliers and pulled the hose off then the metal ring came out
craZed: (2006-12-31 04:37:34)
Dikes.
Lance: (2006-12-31 21:39:21)
not a bad idea. I ended up using mapp gas to burn up the last bit of hose. It was easy with pliers from there.
84z31: (2006-12-31 23:25:31)
it seems like there should be some sort of tool so you can get the intectors off the hoses. are they press fit.
MrwassmanNA2T: (2006-12-31 23:26:35)
? :lol:
OR-Zman: (2007-01-01 07:47:58)
^Yep. But always get them in pairs. One alone can be a bad thing. :wink:
