Forums/Z31P/z31-performance-upgrade-forums engine-management/delete post
Imported from Z31Performance.com Forums{{#if:jjones| — original post by jjones}}{{#if:2011-05-29 16:55:14|, posted 2011-05-29 16:55:14}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/14560-delete-post.html|
jjones: (2011-05-29 16:55:14)
I have an 86 300zx 2+2 n/a. All I need to get it running is an engine wiring harness. Will the harness out of an 85 turbo clip right into the 86 n/a?
Thank you
NissanEgg: (2011-05-29 16:58:32)
Re: 85 Turbo harness in 86 N/A
The idle air control connectors are different as are the idle air control parts themselves.
jjones: (2011-05-29 19:47:51)
Thank you
jjones: (2011-05-29 19:49:57)
What years would work besides the 86 n/a? Would any turbo harness work? They seem to be easier to find.
NissanEgg: (2011-05-30 03:20:41)
All turbo engines have different idle air control parts, so all turbo harnesses will have different connectors for those parts.
Try OEM-surplus.com. They usually have a good selection of harnesses.
