Forums/Z31P/z31-performance-upgrade-forums engine-management/delete please
Imported from Z31Performance.com Forums{{#if:ryaz31| — original post by ryaz31}}{{#if:2013-10-31 04:23:36|, posted 2013-10-31 04:23:36}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/22864-delete-please.html|
ryaz31: (2013-10-31 04:23:36)
Delete please
i r teh noobz: (2013-10-31 12:28:09)
There is no fuel thermostat, so I'm assuming you mean the temperature sensor. Myself and many others have reported absolutely no change with the temp sensor removed. I believe it only affects hot start fueling,
If you just broke the tab off, use a wire wheel to expose a little bit of the tab, then solder a wire to it. I doubt anything will change, but you can try it.
jaqattack02: (2013-10-31 13:25:10)
Try unplugging the O2 sensor and see how it runs.
ryaz31: (2013-10-31 16:58:07)
Ya sorry I meant the temperature sensor.
300zxturboftw: (2013-10-31 19:48:19)
Original question looks edited and deleted, but if you think FTS is effecting how your car runs then reassure, it's not the issue you are looking for if there is a problem.
ryaz31: (2013-10-31 22:00:24)
Ya I tried editing my post.... screwed it up. Anyways im trying to filter out the possibilities of why my car stutters. Timing is dead on. Tps is good. O2 is new and good. Did a pressure test threw my intercooler. Now im starting to think it's just my stock fuel pump. I just didnt think that running 5/6lbs of boost would make that big of difference.
