Forums/Z31P/z31-performance-upgrade-forums engine-management/Wideband as a narrownband
Imported from Z31Performance.com Forums{{#if:Returned Z31 Lover| — original post by Returned Z31 Lover}}{{#if:2014-04-28 15:54:10|, posted 2014-04-28 15:54:10}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/23688-wideband-as-a-narrownband.html|
Returned Z31 Lover: (2014-04-28 15:54:10)
So I got the MTX wideband, and it can also work as a narrowband. Where in the hell does that one wire from the wideband go on the ECU to act as a narrowband? Thanks
michaelp: (2014-04-28 15:56:50)
The O2 sensor signal wire…but only 84-85 ECUs and 87-89NA ECUs will support it, so just keep that in mind if you get a ECU for nistune later.
But honestly, the O2 sensor signals to the ECU are almost useless anyways....especially once you tune the car, its totally not needed. haha
amreboot: (2014-04-28 22:34:04)
^This.
During my tune, we tried to get better results with the simulated O2 narrowband from my wideband. It would make the car run just dumb.
I have been running without an O2 for many years, no issues.
Returned Z31 Lover: (2014-04-29 03:55:32)
Ok so im probably going to be driving with 11 psi for a lil while. When I get my injectors, fuel pump and Nistune then the tuning will start. So should I just disregard that ecu wire? How should I run this wideband in my situation?
