Forums/Z31P/z31-performance-upgrade-forums engine-management/Welcome to my NIGHTMARE please.
Imported from Z31Performance.com Forums{{#if:allen colin Kelly| — original post by allen colin Kelly}}{{#if:2013-07-29 15:21:06|, posted 2013-07-29 15:21:06}}{{#if:14| · 14 post{{#ifeq:14|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/22255-welcome-to-my-nightmare-please.html|
allen colin Kelly: (2013-07-29 15:21:06)
After countless hours and money, my VG30 is ready to go except for one thing. It will not start. I am getting power to my injectors, but no injector pulse. I am getting no ground to fire the injectors. I have tried THREE diffrent ecu's and I get the same result. Someone out there is smart enough to figure this out. I have even had a Nissan mechanic work on it and he has given up. Why am I getting no injector pulse?
DeleriousZ: (2013-07-29 15:34:48)
Bad CAS? Tried replacing the distributor/crank angle sensor?
A good way to easily tell if the injectors are pulsing is to pull the distributor, plug the sensors back in, and spin it by hand with the key in the ignition (turned to 'on' position)
Joe87T: (2013-07-29 15:38:05)
do you have fuel pressure? did you rewire the injectors?
allen colin Kelly: (2013-07-29 15:52:21)
Yes, I have almost 40 pounds of fuel pressure and I used dropping resistors (10 olms) as the ecu is high impudence and the injectors are low impudence.
Careless: (2013-07-29 18:56:00)
check the green/orange relays behind the battery.
allen colin Kelly: (2013-07-29 20:26:57)
Checked the relays also Careless. Seem to be correct.
allen colin Kelly: (2013-07-29 20:54:41)
I might just swap out the relays anyway Careless to make sure, but using a prob light, they seem to work. Never really know.
allen colin Kelly: (2013-07-29 20:56:58)
builds monster engine. loses entire assembly to dipstick failure… [archived image: wink.png] I sure can identify with this.
Careless: (2013-07-29 21:30:29)
lol that wasn't for you. i'll remove it now anyways. joke's old.
Showaski39: (2013-09-27 23:04:52)
I'm having the same exact problem that your describing.
My fuel pump is pumping a solid 55 - 65 PSI right after the fuel filter (before the regulator). I checked some of the injectors that I can reach for power, and they are getting power (with ignition in ON position).
I've checked the 1, 2 and 3 pins on the ditributor for power (w/ ignition switch in ON position also), and I'm getting 11-12V for one of the pins, and 4-5V for the other two. I disconnected the coil wire from the distributor and mated it to a piece of metal under the hood, and I can see spark coming from ths coil wire when trying to start the engine.
I've pulled the spark plugs to find any other signs of possible causes, and the spark plugs looked brand new (I just replaced them). There isn't a bit of carbon deposit on them which led me to believe I wasn't getting fuel. The car ran perfectly fine (it had a little misfire sometimes) until I parked it for several weeks because I was doing some routing maintenance on it (timing, plugs, fuel filter, CHTS, etc.)
Now it doesn't want to start at all. I can barely keep it running if I quickly jab the throttle a bunch of times, but it sounds like it's running on 1 cyliner and complete crap when I do this.
I've about quadrouple checked that the timing marks by the crank, and cam gears line up as they should (with 1st cylinder at TDC).
shromy: (2013-10-07 16:09:51)
Doesn't sound like the ecu is powering up. If it is then continuity check the ground side of the injectors to ecu.
300zxtravis: (2013-10-07 17:38:58)
did you spray some carb cleaner in the intake then crank it? if you have correct timing and spark the engine will ALWAYS runn doing this. if not then your problem may be timing and/or spark. just because you have spark doesn't mean the timing is correct. Those being ok would limit it to the fuel side, check fuel pressure, then make sure the injectors are triggering. if you have pressure but no injectors you have either ECU, or CAS problem. Assuming all grounds have been checked.
Axel kain: (2013-10-26 04:10:35)
please verify cam pulley orientation. L3 is on drivers head, and R3 is on passenger head.
PrideZ31: (2013-10-26 05:18:58)
Sounds like my EXACT problem right now lol.
So far the only thing that makes a difference with this for me is messing with the TPS. Whenever I can get out to a junkyard and find a new TPS, I'll know for sure if it's the problem or not.
