Forums/Z31P/z31-performance-upgrade-forums engine-management/TPS issues
Imported from Z31Performance.com Forums{{#if:mcx| — original post by mcx}}{{#if:2014-04-14 19:33:39|, posted 2014-04-14 19:33:39}}{{#if:1| · 1 post{{#ifeq:1|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/23630-tps-issues.html|
mcx: (2014-04-14 19:33:39)
today the TPS is bugging out…plug it in and the AFR goes to 10[AEM WB]…unplug and it goes to the usual 14ish range…I tested the tps with a MM and the continuity break is fine?? what am I missing here?? thx,mike
