Forums/Z31P/z31-performance-upgrade-forums engine-management/Need help with Turbo harness swap
Imported from Z31Performance.com Forums{{#if:datsunzcar84| — original post by datsunzcar84}}{{#if:2008-09-11 23:41:20|, posted 2008-09-11 23:41:20}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/5602-need-help-with-turbo-harness-swap.html|
datsunzcar84: (2008-09-11 23:41:20)
After many hours of trying to figure out the wiring problems in my 84 Na2T I have come to the conclusion that the ECU is fried . Rather than try to get a new ECU, I want to swap the EFI harness from my 88 Turbo Parts car . The N/A harness that is there now is all Hacked to shit from me replacing broken connectors and age.
So… I am wondering what problems Am I, going to run into as far as mating the EFI harness with the body Harness? Has any one successfully mated a later EFI harness into A early body harness?
datsunzcar84: (2008-09-12 22:50:25)
I received a PM and was informed of this link.
http://www.tboz31.com/300ZX/Z31EFIHarne … wiring.htm
Still not sure on what to do with a few pins . Has any one successfully done this?
datsunzcar84: (2008-10-25 23:47:17)
Can any one help? I am having a bit of trouble .
Is there any one that Would be willing to make me a jumper harness for the connection from the EFI to body harness connections?
ShamWow: (2008-10-31 01:46:50)
Okay. I have spliced an 87 EFI harness into my 84 body harness, and it runs an 84 engine (with 87/84 shit all mixed together).
The diagram you linked is the one I used. I wasn't able to remove the pins from the connector to switch things around, so I just soldered in another connector to get the proper hack job.
what part of this harness hack are you having trouble with specifically?
datsunzcar84: (2008-10-31 02:10:22)
Well there are a few pins, I just am unsure about .
how pins 22, 65 ,on the 84-6 N/A harness and pin 29 and 7 on the 87-9 turbo harnesses are to tie together . Every other pin I know where they need to go .
I have scribbles on wordpad but not sure how to post that here
datsunzcar84: (2009-02-17 22:21:39)
Any one who has done this swap can you help?
ShamWow: (2009-02-17 23:31:15)
..Posting here to remind myself to take a closer look at this after my circuit analysis test..
datsunzcar84: (2009-02-17 23:39:43)
yeah man any help WOULD BE GREAT!!! . I think instead of trying to make a jumper I am going to try to repin the connector . I SUCK at soldering .
