Forums/Z31P/z31-performance-upgrade-forums engine-management/Ignition Timing Question
Imported from Z31Performance.com Forums{{#if:RMWheeler300zx| — original post by RMWheeler300zx}}{{#if:2013-12-09 21:26:48|, posted 2013-12-09 21:26:48}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/23030-ignition-timing-question.html|
RMWheeler300zx: (2013-12-09 21:26:48)
I replaced the EGR with a used one from 300zx Parts For You; and also took care of a damaged camshaft seal that was doing a continuous oil change down the road. Car fired up instantly and showed no signs of wanting to stall out or and idle instability. After a quick test drive, she ran smooth as glass. I took it into the smog shop, and it passed the sniffer with flying colors. They failed it on functional claiming the Ignition Timing was @ 2 degrees BTDC. I find that hard to believe that the car is running that good, with the ignition timing off by about 12-13 degrees.
G-E: (2013-12-10 10:05:22)
EGR lets you run much more advanced timing and use less fuel at light throttle, I don't understand the fascination with removing it
jaqattack02: (2013-12-10 14:34:32)
Wait, so it passed the sniffer tests and still fail you because they don't like where your timing is set? What kind of crap is that?
Tempast: (2013-12-11 02:21:32)
Why would they care what the timing is at if the car is running right. The whole point of being able to adjust the timing is to be able to tune the car for emissions and driveability.
Big_E-Dog2: (2013-12-15 08:24:52)
well for all you country ppl who dont have to do smog and dont know what it is. your car basically needs to be the way it was when it was new when it goes into smog. thats what the arb tested it as for emissions. this includes timing.
you coulld have the wrong crank pulley....
Big Slappy Z: (2013-12-20 04:05:16)
Where the fuck do they check ignition timing at inspection? That's stupid. Relocate immediately.
michaelp: (2013-12-24 05:18:02)
Z31s have no balls with less than 17°BTDC - it wouldn't even run with 2. I'm not sure 2 can even be achieved unless the distributor is off a tooth.
