Forums/Z31P/z31-performance-upgrade-forums engine-management/Fuel tank O rings
Imported from Z31Performance.com Forums{{#if:FairladySPL| — original post by FairladySPL}}{{#if:2023-01-12 14:03:49|, posted 2023-01-12 14:03:49}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/546419-fuel-tank-o-rings.html|
FairladySPL: (2023-01-12 14:03:49)
Anyone have a solution for new o rings for the fuel tank and probably the screws for the plates? Past Power Products seems to have made a kit but they are not responding and it shows "Out of Stock" Been searching around with no luck. Want to replace my pump with a walbro and check the status of the inside of the tank as it has been sitting for years.
Z_Karma: (2023-01-12 20:49:02)
https://www.thezgarage.net/store/p35/gastankseal.html
FairladySPL: (2023-01-13 13:48:56)
Thank you so much, a wave of relief has washed over me [archived image: cool.png]
