Forums/Z31P/z31-performance-upgrade-forums engine-management/Fuel injector question.
Imported from Z31Performance.com Forums{{#if:Dman| — original post by Dman}}{{#if:2007-03-26 07:11:35|, posted 2007-03-26 07:11:35}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/1947-fuel-injector-question.html|
Dman: (2007-03-26 07:11:35)
Hey guy's I need to know something.
I have a 97 pathfinder engine vg33.
I'm wondering what cc these injectors flow, and also if they are high or low impedance?
Thanks in advance.
Steve88t: (2007-03-26 14:47:30)
Can't answer specifically, but if my memory is right, they are
Jason84NA2T: (2007-03-27 00:37:18)
Steve88t wrote: Can't answer specifically, but if my memory is right, they are
Dman: (2007-03-27 08:05:15)
Thanks, I am in the beginings of doing the vg33 for my 510wagon (already has a vg30) and I wonder if using the pathfinder injectors would be better than the stock na vg30 ones, or better yet would I be able to run these pathfinder injectors from an 88-89 ecu. I am thinking if they are close or the same flow rating as stock 300zx na injectors and also high impedance I could run my 88-89 ecu without any worries. I don't want to disable my car any longer than I have to, so being able to use all the vg33 stuff would be nice. Or am I just being foolish to try and use the vg33 lower and injectors. Mainly I'm being cheap right now but I have the stuff so why not use it.
Thanks for you help guys.
zmech: (2007-03-27 15:07:09)
z
Dman: (2007-03-28 01:52:22)
Yeah I have a complete vg33 from a 97 pathfinder, so thats why I ask.
I would like to just use it the way it is, only problem now is I will have to have a chip burned to compensate for the larger cc injectors as the 88-89 na ones are aroung 174cc. What kind of injector choices are there for the pathfinder lower plenum?
Sorry for so many questions, my knowledge on this aspect is highly lacking and I figure that here is where the experts are.
Thanks alot for your guy's patience.
  • edit* I ended up buying nistune but still haven't pieced it all together yet.
Yancy97pathfinder: (2017-11-29 06:35:56)
I also need help if anyone has a schematic of were to put the belt pully brackets would be awesome!
Dunkine: (2017-11-29 18:35:09)
This is a thread from 2007. Do you need a schematic for a 300zx or a pathfinder? If you are looking for pathfinder stuff, might want to hit up a pathfinder forum.
