Forums/Z31P/z31-performance-upgrade-forums engine-management/Fuel Injector O-rings
Imported from Z31Performance.com Forums{{#if:300zxturboftw| — original post by 300zxturboftw}}{{#if:2013-08-31 22:09:58|, posted 2013-08-31 22:09:58}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/22495-fuel-injector-o-rings.html|
300zxturboftw: (2013-08-31 22:09:58)
Do you need special o-rings for E85? Where can I find some ethanol grade 11mm's for rx7 injectors?
FlawleZ: (2013-09-01 06:32:49)
I'm running standard rings. I don't believe its neessary to run anything any different as all the modern hoses and rings are made to withstand ethanol content in gasoline since the 80's.
