Forums/Z31P/z31-performance-upgrade-forums engine-management/External Fuel pump and fuel sump.
Imported from Z31Performance.com Forums{{#if:onefast87| — original post by onefast87}}{{#if:2016-09-26 16:40:51|, posted 2016-09-26 16:40:51}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/532501-external-fuel-pump-and-fuel-sump.html|
onefast87: (2016-09-26 16:40:51)
Hey guys, im in the middle of redoing my entire fuel system for my LS swap. Ive got some -8AN for the feed and a -6AN for return. I also have a weld on sump for the tank.
Was hoping you guys could post up some pictures of your sumps and external pumps for some extra motivation.
And GO!!
88sinZ: (2016-09-27 05:10:55)
I think the greatest flaw of the fuel tank is no slosh baffles. In with that argument is the cause for a baffled fuel cell.
It does have a solid up swept area on the rear that should fit some universal sump pans. Was about to pan it before figuring out an in-tank solution, it doesn't like to be under 1/4 tank though.
nismo kid: (2016-10-14 23:05:30)
Here's FlawleZ setup
onefast87: (2016-10-18 19:19:03)
Thanks for the replies, this place doesn't seem as busy as it used to be. I guess its just easier to do it then to come online and ask. I will post up my setup when I complete the fuel system.
88sinZ: (2016-10-19 06:10:07)
defiantly not, both a blessing and a curse helping weed out the discourse.
Sometimes you just gotta cut into the guts of it.
onefast87: (2017-01-04 16:40:25)
I got most of it in the car, but before I finalize it, im wondering for those who have put in stainless fuel lines in their car, where are you running the lines? Seems a little bit tight over the subframe, wich is where my issue is. I ran the lines pretty much where the factory lines were. Anyone have any pics to share??
