Forums/Z31P/z31-performance-upgrade-forums engine-management/ECU pin out description
Imported from Z31Performance.com Forums{{#if:JSM| — original post by JSM}}{{#if:2017-02-21 02:35:06|, posted 2017-02-21 02:35:06}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/534447-ecu-pin-out-description.html|
JSM: (2017-02-21 02:35:06)
Does anyone have a pin for pin difference between the 84-89 ECU and their description?
88sinZ: (2017-02-21 06:13:03)
yes, the FSM.
Cite 84-87 FSM for 84- to mid 87, cite '89 FSM for +12/87-89 models as its the most applicable revision
i keep a pin out and full wiring diag magnet to my upper box for reference and have found the 87 to 88 FSM non-applicable to 12/87+ models
nismopick: (2018-08-30 19:13:05)
Found this unanswered thread as I was researching Z31 ecu pinouts. I do have a complete comparison for the 280ZXT and Z31 ECCS… used for my write-up for using the Z31T ecu on the 280ZX Turbo.
Compare 1.jpg (285.9 KB)
