Forums/Z31P/z31-performance-upgrade-forums engine-management/Crane Cams 6000-6300 HI-6S Multi-Spark Ignition?
Imported from Z31Performance.com Forums{{#if:Rahlude92| — original post by Rahlude92}}{{#if:2014-05-19 07:34:16|, posted 2014-05-19 07:34:16}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/23759-crane-cams-6000-6300-hi-6s-multi-spark-ignition.html|
Rahlude92: (2014-05-19 07:34:16)
Any reviews? Considering my options
Butter: (2014-05-19 12:45:28)
Options for what? What do you want it for?
I have the HI6R.
Rahlude92: (2014-05-19 15:47:33)
To replace factory fuel cut limiter. For faster fuel recovery time. So its a faster spark cut than the regular 3 sec fuel recovery fuel cut limiter
Butter: (2014-05-19 20:37:48)
Yeah, it's pretty good at that. Nice and soft. I hit it all the time.
I have the LX92 coil, and you also need this tach adapter…
http://www.summitracing.com/parts/cr…FXQ1Mgodc2sA3Q
Noticeable improvement in response and smoothness. Got even better when I added the PRW-2. Nothing that will blow you away though. You can actually hear it when it's running in multispark mode. Makes a kinda whining sound.
The "R" is for wet environments. I would get that if you want to mount it under the hood.
Rahlude92: (2014-05-19 21:04:44)
So is rev limit more rapid than the factory fuel cut with tour setup?
