Forums/Z31P/z31-performance-upgrade-forums engine-management/Anyone on here using F.A.S.T???
Imported from Z31Performance.com Forums{{#if:ralph50| — original post by ralph50}}{{#if:2015-04-20 13:59:14|, posted 2015-04-20 13:59:14}}{{#if:10| · 10 post{{#ifeq:10|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/24959-anyone-on-here-using-f-a-s-t.html|
ralph50: (2015-04-20 13:59:14)
I'm getting a really good deal on one.
I considered Nistune but my entire engine harness is falling apart and don't want to deal with 31 year old sensors.
jaqattack02: (2015-04-20 14:08:49)
I wasn't aware they made anything not intended for an LSX/SBC. What product are you planning to use, exactly?
ozzyrulez: (2015-04-20 14:56:12)
Wow for the price just their ECU you can get Megasquirt 3 with Megasquirt Extra with both harnesses, VG30 trigger wheel, boost control solenoid, GM CTS and GM IAT with pigtails, the knock module kit, their "MAP Daddy" 4 BAR dual MAP. Then you can use the rest of the money you save to buy LSX coil packs to do full sequential fuel and spark.
ralph50: (2015-04-20 15:17:04)
Its the Felpro FAST aka FAST Classic.
I'm switching to GM sensors and a wideband O2 sensor.
I'm partial to this unit as my buddies have used it before.
ralph50: (2015-04-20 17:22:51)
I'm getting it for $650
jaqattack02: (2015-04-20 18:52:26)
From the way things are going so far, it seems like you'll have to get help from your buddies then, as I don't think anyone here has used any of the FAST stuff. Definitely post a build thread or something, in case someone else decides to go that way.
turbofedz: (2015-04-21 00:58:57)
That's a very good price $650.do it!!!an let us know how did it go.
ralph50: (2015-04-21 12:08:27)
Thanks for the input. It might be a while though as there are a few custom parts to build.
My buddy ran this ECU on his turbo SBC so he is familiar with the system.
NissanEgg: (2015-04-21 16:55:09)
Are you trying to adapt this system to a Nissan V6?
ralph50: (2015-04-22 14:40:06)
Yes. I'm doing away with the Nissan harness and sensors. Going with GM sensors, Mototron 60# injectors, custom manifold and BBK throttle body.
