Forums/Z31P/z31-performance-upgrade-forums engine-management/AEM simulated narrowband output.
Imported from Z31Performance.com Forums{{#if:14Psiplease| — original post by 14Psiplease}}{{#if:2011-04-04 20:38:17|, posted 2011-04-04 20:38:17}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/13988-aem-simulated-narrowband-output.html|
14Psiplease: (2011-04-04 20:38:17)
The AEM manuel says it puts out 0-5 volts, but on jasons website it says the Zirconium sensors relay a 0-1v signal and Titania sensors vary resistance to give the ECU its mixture feedback data. So my question is it even possible to use the output from the wideband to simulate a narrowband signal with our ECU's and lets say i have both Zirconium(84-85) and Titania(86-89) ECU's.
88sinZ: (2011-04-04 20:59:14)
Most sensors use a 0-1v signal, and most widebands have a analog output for running to the ecu to keep it happy, check back over the AEM manual or check their forums.
14Psiplease: (2011-04-04 21:58:25)
https://dev.z31library.com/external_images/www.schnitzracing.com/manuals/AEMWBK.pdf
OK heres the manuel…soooo looking at page 9 and 10 I would need to configure it to P4 to simiulate a 0-1v output,right?
Next question! So after i do that, all i do is splice the wire from the wideband into the wire that goes to terminal "24" on the ecu and im good to go if im using a zirconium ECU? What about a Titania ECU, jason says it varies resistance to show lean or rich.
88sinZ: (2011-04-04 23:22:21)
I can tell you this much, the innovate lc-1 has configurable output to set your "stoic" voltage range
Yes pin #24 is your 02 reference signal, it looks like P4 is the selection you should use
Keep reading the manual, it seems most widebands users here use innovate though there are a few UEGO users
SATAN: (2011-04-08 22:57:44)
If it outputs voltage, then it cannot simulate resistance.
88sinZ: (2011-04-09 00:08:06)
just curious, the FSM doesn't list a difference about the 0-1V pickup@ the ECU
If the sensor varys voltage received at the ECU than in theory it could be done.
SATAN: (2011-04-09 02:28:04)
I have no idea about that. If you think it can be done, then I will take your word on it.
