Forums/Z31P/z31-performance-upgrade-forums engine-management/1984 na ecu
Imported from Z31Performance.com Forums{{#if:Zedstar| — original post by Zedstar}}{{#if:2018-03-20 08:57:36|, posted 2018-03-20 08:57:36}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-management/539021-1984-na-ecu.html|
Zedstar: (2018-03-20 08:57:36)
Cannot find info on how to socket/upgrade EPROM on this ECU. There is plenty of info on how to install Nistune Board, however only want to swap EPROM for injector upgrade
kaur: (2018-03-20 13:33:30)
There might be some info on older pages. Like this for example http://redz31.suomiz.net/pages/fuel/romulator.html
Dunkine: (2018-03-20 15:40:56)
XenonZCar - https://dev.z31library.com/xenonzcar_archive/z31/nistune.php
and yes, it's about installing the NIStune board, but it shows the EPROM for the 84-85 for fuel & timing maps.
Zedstar: (2018-03-20 22:58:55)
{{#if:Dunkine|Dunkine wrote:|Quote:}}
Thanks for your reply.
However , the instructions only relate to connections from the Nistune Board to CPU chip etc - not an EPROM. It appears that a replacement EPROM can be only loaded to later i.e 88ECU which are single EPROM.
