Forums/Z31P/z31-performance-upgrade-forums electronics-aa/vg30et swap speed sensor question
Imported from Z31Performance.com Forums{{#if:mynameisjonas83| — original post by mynameisjonas83}}{{#if:2019-10-12 15:12:46|, posted 2019-10-12 15:12:46}}{{#if:1| · 1 post{{#ifeq:1|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/electronics-aa/544631-vg30et-swap-speed-sensor-question.html|
mynameisjonas83: (2019-10-12 15:12:46)
I searched the fsm and this site and I still can't wrap my mind around what I need. I swapped in a 86 vg30et from an AT digidash car into my 86 NA MT analog dash car. I kept the MT and the analog cluster. I swapped in both the EFI and Engine room harnesses. I kept the original main harnesses in place. Since the NA setup does not send speed sensor input to the ECU (according to EF and EC-6 in FSM) but the Turbo setup requires this (EF and EC-7) how do I remedy this? Pin 29 (EF and EC-9) is for the speed sensor but this doesn't exist in the NA main harness to Turbo harness connector as you can see in the diagram. I really hope this makes sense.
