Forums/Z31P/z31-performance-upgrade-forums electronics-aa/Rear view camera wiring
Imported from Z31Performance.com Forums{{#if:sagekh| — original post by sagekh}}{{#if:2019-07-10 06:40:10|, posted 2019-07-10 06:40:10}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/electronics-aa/543829-rear-view-camera-wiring.html|
sagekh: (2019-07-10 06:40:10)
Picked up an aftermarket head unit with a rear view camera, but canât find anywhere to run the camera wire through the chassis into the interior. Where should I run the wire?
FrozenZ: (2019-07-11 18:19:18)
where are you putting the camera?
sagekh: (2019-07-12 01:15:18)
Anywhere I can mount it while not looking terrible
Any suggestions?
mwolvinm: (2019-07-12 16:26:28)
Without knowing the camera mounting dimensions or year of your car or how the camera is supposed to mount, this could be a little… challenging.
Maybe remove the lock cylinder for the hatch and put it there? Or secure it above the licence plate then route it through some of the holes behind the center trim pieces?
