Forums/Z31P/z31-performance-upgrade-forums driveline-aa/what clutch for 400-450hp?
Imported from Z31Performance.com Forums{{#if:millsaps| — original post by millsaps}}{{#if:2013-04-19 01:47:05|, posted 2013-04-19 01:47:05}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/21286-what-clutch-for-400-450hp.html|
millsaps: (2013-04-19 01:47:05)
i plan to go holset and in the end want 400hp don't want to buy a clutch twice. i have a spec in my truck holds great but thats like 120hp, my s13 had some nice stage 2 and 300ish. what will i need for a z31 at 400?
Axel kain: (2013-04-19 04:09:38)
http://store.acadianasportscars.com/…9-nissan-300zx
NissanEgg: (2013-04-20 04:56:00)
Clutches are rated in torque capacity, not horsepower.
300zxturboftw: (2013-04-20 14:22:06)
Go with DXD/South Bend Clutch kevlar kit. Clutch will last you a long time and hold down as much power you will ever throw at it or until you blow up your engine.
Careless: (2013-04-20 14:39:40)
i loved the dxd stage 4 I have in z. its easy to drive and holds anything i put it through. although, i did find downshifting smoothly with a heavy clutch to be a little more finnicky. maybe when it starts to burn in a bit more it would be easier.
millsaps: (2013-05-05 03:36:02)
the stage 3 daily is rated at 530 ft/lbs. i wouldnt be running extremely sticky tires. it would also probably make a few passes on the strip. anyone use the dxd stage 3 daily? it will be through an na trans.
NissanEgg: (2013-05-05 04:00:37)
That's what I run, at least before they changed the lineup of the staging names. I love it. Not to hard on the pedal, smooth engagement. Clutch does make a hissing noise as it is slipping when starting off in 1st or reverse since it has the feramic disc.
millsaps: (2013-05-05 23:08:45)
better than the throw out bearing whine in my d21, what is done to your motor and about how much power are you making
