Forums/Z31P/z31-performance-upgrade-forums driveline-aa/vg33e clutch
Imported from Z31Performance.com Forums{{#if:Quickshift| — original post by Quickshift}}{{#if:2012-08-02 22:00:36|, posted 2012-08-02 22:00:36}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/18836-vg33e-clutch.html|
Quickshift: (2012-08-02 22:00:36)
I was wondering what I could do about a clutch if I swapped in a vg33e. I figured I could just look up a clutch for the car I was taking it out of, but I can't seem to find one for an infinity qx4, i'm guessing because it only came with an automatic. Are 3.3L flywheels the same as a 3.0? so I can use a 3.0 clutch? or can I use a 3.0L flywheel on the 3.3L rotating assembly?
NissanXRMA: (2012-08-02 22:16:29)
Use Vg30e flywheel and clutch/pressure plate assembly.
Careless: (2012-08-02 22:19:40)
if you're putting the engine in a z31 with a z31 transmission, use the z31 parts.
a VG33 swap is really as simple as it gets. you're basically just adding 10% more displacement. aside from that- use as many z31 parts that you can possibly use- and it will be easier for you.
Quickshift: (2012-08-04 04:58:15)
I picked up the vg33e. it didn't come with any accessories, so i guess that's the next thing I have to sort out.
