Forums/Z31P/z31-performance-upgrade-forums driveline-aa/drive shaft change out.
Imported from Z31Performance.com Forums{{#if:jerryparks| — original post by jerryparks}}{{#if:2014-03-13 19:23:28|, posted 2014-03-13 19:23:28}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/23442-drive-shaft-change-out.html|
jerryparks: (2014-03-13 19:23:28)
I have a sqeeky drive shaft on my '87 turbo-which I think is a U joint on the drive shaft. I have a extra '86 non turbo drive shaft I could use- if it will fit OK. Will this exchange work OK? Both drive shafts are for 2 seaters.
jaqattack02: (2014-03-13 20:04:58)
No, the output shaft of the tranmission is different going from the non-turbo (71C) to the 87 turbo (30A). The companion shaft on the diff side also should be different going from an 86-87.
jerryparks: (2014-03-13 21:14:39)
Thanks for the info-- this saves me a lot of labor time.
