Forums/Z31P/z31-performance-upgrade-forums driveline-aa/clutch question
Imported from Z31Performance.com Forums{{#if:onefast87| — original post by onefast87}}{{#if:2014-03-12 08:35:39|, posted 2014-03-12 08:35:39}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/23434-clutch-question.html|
onefast87: (2014-03-12 08:35:39)
i would like to know if its a bad idea to use a new disc with a used pressure plate.
I have an act street clutch HD that just started slipping.
im not looking to buy a new clutch, just need it to make a few more months until i do my engine swap, while taking 400 foot pounds torque.
Maxim0018: (2014-03-13 01:40:45)
I would slide it on without resurfacing the pressure plate. Would you run a new clutch without resurfacing a used flywheel?
onefast87: (2014-03-13 18:53:30)
I was not concerned about the flywheel, its a fidanza with low kilometers, just wanted to know if its a bad idea
