Forums/Z31P/z31-performance-upgrade-forums driveline-aa/Troubles with this diffmount
Imported from Z31Performance.com Forums{{#if:85300zxnissian| — original post by 85300zxnissian}}{{#if:2014-02-22 09:37:41|, posted 2014-02-22 09:37:41}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/23352-troubles-with-this-diffmount.html|
85300zxnissian: (2014-02-22 09:37:41)
So i purchased this diffmount (https://dev.z31library.com/extras_archive/www.arizonazcar.com/) thinking it would be an easy install, its for an r200 long nose and is made for the 280zx, and the 280zx is pretty similar to the z31. But i got the old one off, the one that looks like this 001djss.jpg and now i don't think i can use the one i paid for. Is there any way i can use the new one? Should i just try and get a refund? What do you guys think?
Also, what does that wire do? When i was taking off my diffmount the wire was disconnected but barley touching the connector. Is that bad? I was going to put it back in there when i put it back together.
G-E: (2014-02-22 09:59:24)
The wire is a ground strap, normally the entire rear end is isolated by rubber, in theory it could build up a charge…
You should have considered buying a diff mount for _your_ car, not a different car… you could make it work if you're clever, but what's the point, return it…
BTW did you change your subframe bushings yet?
NissanEgg: (2014-02-22 15:00:43)
Don't assume just because it fits a R200 in a S130 chassis it will fit a R200 in a Z31.
ASSUME makes an ASS out of U and ME.
Return it. No ifs, ands, or buts.
85300zxnissian: (2014-02-24 05:31:15)
{{#if:G-E|G-E wrote:|Quote:}}
I have them just not installed.
Haha i see what you did there. Yea i will just return it but thanks for the advice guys.
