Forums/Z31P/z31-performance-upgrade-forums driveline-aa/Tri-Tri hybrid axle positioning spring cut?
Imported from Z31Performance.com Forums{{#if:supertoad120| — original post by supertoad120}}{{#if:2009-08-17 17:28:28|, posted 2009-08-17 17:28:28}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/8171-tri-tri-hybrid-axle-positioning-spring-cut.html|
supertoad120: (2009-08-17 17:28:28)
I have j30/z31 hybrid t-t axles that are going in my 87. How much of this positioning spring can I cut?
supertoad120: (2009-08-17 17:59:55)
Nnever mind. I got them to fit. I had to put the wheel side in first then bring the diff side down from above the flange at an angle. Very tight fit, I'm a little worried about them binding up when the suspension is compressed.
Matt89: (2009-08-17 19:35:51)
You should check for binding when the shafts are parrellel to the ground.
supertoad120: (2009-08-17 19:48:36)
Yeah I'm going to jack up on the control arm and spin the wheel. I would hate to hit a bump and blow up one of my new joints. Thanks
