Forums/Z31P/z31-performance-upgrade-forums driveline-aa/Trans Rebuild Kits
Imported from Z31Performance.com Forums{{#if:easarcher| — original post by easarcher}}{{#if:2012-09-14 16:36:31|, posted 2012-09-14 16:36:31}}{{#if:12| · 12 post{{#ifeq:12|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/19252-trans-rebuild-kits.html|
easarcher: (2012-09-14 16:36:31)
I have the 71C trans, and it is starting to grind some gears. The tranny is out of the car at the moment, so I wanted to rebuild it. Does anyone have any experience with rebuild kits? If so, what is a good brand? I work at Advance Auto Parts, and I currently have my hands on a Pro-King brand kit.
G-E: (2012-09-15 09:54:39)
It might be cheaper to source another 71c in good shape, people with big turbos toss those away regularly…
james: (2012-09-15 10:10:42)
How much do you get the kit for ?
I have never done a gearbox myself but a few diff rebuilds, if you have the correct parts and tools and can follow the FSM then i say do it.
easarcher: (2012-09-15 10:43:32)
I can pick the kit up for for5 bucks, that includes all bearings, seals, and rings.
Careless: (2012-09-15 11:06:42)
that sounds like a soft rebuild kit.
which is just bearings and seals.
no synchros or anything actually worth opening a trans for.
easarcher: (2012-09-15 11:21:24)
It has the brass rings too, but not the synchro sleeves
easarcher: (2012-09-15 11:31:01)
I just noticed my phone didn't catch some numbers. The kit is 105.
Mitchd03: (2012-09-15 13:22:56)
I need one for my POS T-5. Noisiest, notchiest, nastiest gearbox I've ever had in a car with the worlds slowest 2nd gear synchro. The bellhousing doesn't come off the T5 does it? I can't build one on the side then swap them over one day.
Careless: (2012-09-15 13:51:29)
yes, you can remove the bell housing.
Mitchd03: (2012-09-15 16:38:33)
Awesome. Z31 T5 the same as others? Or have I got to buy a Z31 T5?
Gregmatic: (2012-09-16 18:41:23)
It must be a Z31 T5. Mustang, Camaro, 280zx, etc all are not fully compatible, input shaft/bellhousing differences.
Guardian: (2012-09-21 09:51:44)
I'm in the process of rebuilding my 71c. Ordered a ebay kit a year ago and now regret. Some of the synchros don't match and also didn't give me all the synchros needed for a proper rebuild. Everything else seems to work. Just ordered a synchro kit from Drivetrain.com. I'll get back to you if I would recommend. So far 300 bucks worth in kit cost. Plus having a friend of mine doing the rebuild for 2-300. But, Even with all that, I would still rather have my own rebuilt tranny then something I'd pick up from a salvage yard. Fresh and clean any day. I'll have no worries about popping a tranny because of the previous owner's failure to properly maintain his car.
Also one very important thing that I found out about the 71c: Nissan loves to change their stuff half way through a year. Their are 83-87 and 87-89 rebuild kits. Very slight differences but it was enough to make me buy another kit.
