Forums/Z31P/z31-performance-upgrade-forums driveline-aa/Rebuild of OEM CLSD
Imported from Z31Performance.com Forums{{#if:joselito76| — original post by joselito76}}{{#if:2016-02-27 03:46:06|, posted 2016-02-27 03:46:06}}{{#if:10| · 10 post{{#ifeq:10|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/25633-rebuild-of-oem-clsd.html|
joselito76: (2016-02-27 03:46:06)
I replaced the clutch pads on my 1988 turbo manual Z. First off, I don’t know if the automatics came with a different CLSD, but from my investigation they are two different carriers. The only difference between the two that I know is the bolts that hold the carrier together. One has 3 screws holding it and the other 4 screws. Mine is a 2.0 way 4 screws.
Now to the clutches they are 2 kit that fit our carrier
Part number 3843S-RS651 solid pattern (probably for a 1.5 way)
Part number 3843S-RS521 lines pattern (probably for the 2 .0 way) I dont have a picture for it.
But they are interchangeable mine is a 2.0 way and I used the solid pattern.
They are 12 clutches or( friction disc or plate)
1 Friction disk engage to the inside the parts that drives the axle
2 Friction plate engage to the carrier turn by the ring gear
2 springs disk the same as the friction disk, but it is concave and keeps the clutch pack loaded
4 springs plate same as the friction plate, but it is concave and keeps the clutch pack loaded
The more spring plates or disc the higher the breakaway of the clsd.
The one in my car came with 2 friction plates 2 springs’ plates and only on friction disc, so is only one disc per side transferring the power to the ground( not good). Both of the kits come with 2 spring plates,1 spring disc, 1 friction plate and 2 friction disk ,so 3 friction disc per side transferring the power to the ground and the extra spring increase the breakaway .The factory is 8Kgf and the Nismo kit is 12 kgf breakaway.
When the carrier is free from the ring gear then you can access the screws that hole the cap together. The carrier is mark if is not make sure to mark the two parts together.
This are the screws that I am talking about some use 4 some use 3
When you remove the top this is how is going to look.
Remove the clutches and pressure ring this is how is going to look
Without the clutches
joselito76: (2016-02-27 04:14:42)
Repair of CLSD
With the clutches
Then you have the pinions inside remove the pinions to gain access to the other pressure ring .On the outside of the clutches there is a big washer you don’t need it any more with the nismo kit. They are two, one on each side. The small washer that came in the kit goes on the small holes of the carrier one on each side.
Big washer not need it they are two one on each side
small washer in the hole
Both pressure rings out
Remove all the clutches from the pressure ring
The FSM ask you to take measurement,but because I am not replacing anything else I am not taking the measurements, so is up to you.
Now to put it back together I find out that is easier to put the clutches on the pressure ring first. (Remember the spring clutches are on the outside with the concave parts to the outside. If you put the clutches in the pressure ring first the order is
Friction disc
Friction plate
Friction disc
Spring plate
Spring disc
Spring plate
This is the order if you decide to put them in the pressure ring first and remember 6 per side.
Remember concave side to the outside. Now put everything back in reverse order. When everything is in the last clutch should be flush on the carrier case. Make sure the mate pinion is in place. Now line up the two half Loctite the screws and done.
joselito76: (2016-02-27 04:22:20)
CLSD clutches repair
Pressure ring with clutches
Concave side
After everything is in the last clutch should be almost flush to the carrier
Remember to put the small washer before putting the lid I almost forgot to do that.
match the marks
joselito76: (2016-02-27 04:37:42)
Make sure the pressure ring are set with the pinion mate
The pinions on mine showed sigh of wear,but they are NLA and I could not find anything .
If you have questions or find something new let me know ,so I can included here. Or if I am wrong on something let me know ,so I can corrected . I did the best with what I could find.
And sorry for the bad English I will fix it as I find things wrong .
Old set as you can see the old set only has 2 Friction disc 1 per side that is the disc that put the power on the CV axles. Not good after 30 years of use they get week
turbofedz: (2016-02-29 02:11:03)
Good info thanks.
Augustus Maximus: (2016-03-01 04:43:50)
Thanks Jose, I ordered the kit but it's on backorder
mtherkamp: (2016-03-01 20:20:58)
There is a guy on hybridzcar that sells just the friction parts in a set of 4 or 6 and can get them to you within a couple days if you are pressed for time. I just ordered from him late last week and got them Monday.
Augustus Maximus: (2016-03-03 19:47:48)
I've been sitting on a set I bought from Gary Savage a few years ago. I want the serrated ones.
mtherkamp: (2016-03-03 19:52:49)
Any reason for the preference?
Augustus Maximus: (2016-03-04 20:12:11)
Better and the higher price reflect that as well.
