Forums/Z31P/z31-performance-upgrade-forums driveline-aa/Q45 diff to driveshaft flange
Imported from Z31Performance.com Forums{{#if:cesar| — original post by cesar}}{{#if:2012-10-04 03:05:35|, posted 2012-10-04 03:05:35}}{{#if:11| · 11 post{{#ifeq:11|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/19435-q45-diff-to-driveshaft-flange.html|
cesar: (2012-10-04 03:05:35)
Hey guys I have been calling driveshaft shops to get the flange for my driveshaft since I went with a Q45 diff on my s13 subframe swap and none have the specs for them :-? . Just wanted to know if anyone knows the specs or where I can buy one?
Thanks,
Cesar
G-E: (2012-10-04 04:58:30)
Take it off and give it to them.. or swap in the s13 flange?
cesar: (2012-10-04 05:47:30)
Yeah thats what I will end up doing the thing is it's a 2 hour drive plus everything is all bolted up but I might have to just take it down and take the diff.
G-E: (2012-10-04 06:15:49)
Or to a chalk template of it on paper if you feel artsy
cesar: (2012-10-04 07:22:20)
Found this while searching http://www.drive-lines.com/catalogs/mas … nge%20yoke seems like the part number is 3102-69 but will verify tomorrow
RedDemon: (2012-10-07 14:35:23)
This is what I sent Shaftmasters when I ordered my driveshaft. Ignore the length if you're using a stock tranny, 1010mm is if you have a z32 transmission/s14 sub-frame combo.
cesar: (2012-10-07 17:43:37)
Thank you sir you are a life saver. Are you using the 90-96 diff?
RedDemon: (2012-10-07 18:03:35)
I'm not really sure if I have the 90-96 or the 97-01 diff. The guy I bought if from told me but I forgot.
cesar: (2012-10-07 19:06:41)
Do you have 5 bolt or 6 bolt axles?
RedDemon: (2012-10-07 21:04:31)
They are 6 bolt axles
cesar: (2012-10-08 07:48:25)
Nice! So that means you have a 90-96 q45 diff, you have a q45 axle and one twin turbo axle correct? Later ones are 5 bolt axles
