Forums/Z31P/z31-performance-upgrade-forums driveline-aa/Odd Output Shaft on trans…help needed
Imported from Z31Performance.com Forums{{#if:aksabin4| — original post by aksabin4}}{{#if:2013-07-14 19:33:26|, posted 2013-07-14 19:33:26}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/22109-odd-output-shaft-on-trans-help-needed.html|
aksabin4: (2013-07-14 19:33:26)
Ok, I have a project that was going smoothly until now (I know, that is everyones story on projects…lol). I am attempting to squeeze a VG30 into a 66 Fairlady Roadster. I recently purchaced the trans that used to be in 1SICKZ. The outputshaft on the trans does not match any stock driveshaft I have so far. The ID on the trans output shaft is 32mm where the input on the driveshafts are 30mm. The driveshafts I have tried so far are from an 87 2+2 NA car and an 85 2seater turbo (both 5sp). I have tried to pull up research online on driveshaft specs and have gotten nowhere. I am open to suggestions, any help would be appreciated.
Thanks,
Al
Gregmatic: (2013-07-14 19:38:21)
The easiest way to do this would be to include a picture, most of us can ID a tranny visually with ease. Based on what I know and process of elimination you have tried: a 71c driveshaft and a 90a (T5) driveshaft. 30a trannies are stronger and have larger output shafts than all other trannies, so that would be my guess.
NissanEgg: (2013-07-14 19:42:05)
I too have a 1sickZ tranny and it is a 30A. As far as I know, he only used the 30A transmissions in his car. You will need to find a 87-89 Z31 Turbo driveshaft for it fit into the trans.
aksabin4: (2013-07-14 20:22:06)
Yep…found it, and it is a 30a trans. Now to find the right shaft…lol. Thanks folks!
