Forums/Z31P/z31-performance-upgrade-forums driveline-aa/Nismo Fork Pivot
Imported from Z31Performance.com Forums{{#if:jaqattack02| — original post by jaqattack02}}{{#if:2013-04-23 15:29:29|, posted 2013-04-23 15:29:29}}{{#if:10| · 10 post{{#ifeq:10|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/21333-nismo-fork-pivot.html|
jaqattack02: (2013-04-23 15:29:29)
Anyone seen one of these before? It says it's for the RB20/VG20ET. Couldn't find any info on the RB, but according to Xenon the VG20ET came with a 71C. Any idea if this would work in our 71C? Has anyone tried it?
http://www.auction-jp.com/item/c378117064/
Careless: (2013-04-23 17:41:24)
it should! good find.
85NA2T: (2013-04-23 20:09:03)
The one from zspeedperformance also works.the one that is available with the heavy duty clutch fork.
jaqattack02: (2013-04-23 21:43:24)
Doesn't work with the 71c, 30a only.
PegCityZ: (2013-04-23 22:35:50)
Doing a quick Google of the Nismo part number from the add, 30537-RS540, it is the same part number for the s13/s14/r31 etc, all 71c transmissions I believe, so it should work. It also lists the length at 41mm, which should be easy to check and match with a stock pivot ball.
Also found the Nismo 30a tranmission pivot ball part number to be 30537-RS581, it lists r32/r33/r34/z32 as compatible vehicles.
85NA2T: (2013-04-24 04:08:47)
I'm running one as we speak.not the fork obviously.did you try it and have issues?
jaqattack02: (2013-04-24 12:43:32)
You're the first person I've seen say it works. Everyone else I've seen who tried it had problems.
85NA2T: (2013-04-24 16:05:07)
Hmmm thats odd.I know the fork wont work but my pivot was the same? Idk
jaqattack02: (2013-04-24 17:01:34)
I'm not at a point of needing one yet anyway. I was just posting it in case someone else did since I didn't know NISMO made one.
PegCityZ: (2013-04-24 17:17:43)
The reason being is that the fork upgrade needs a shorter pivot ball to work. It seems that Nissan used a shorter pivot ball for the 71c transmissions and 2004+ 350z. A longer one was used for the 30a and 2003 350z transmissions.
Pic I found:
[archived image: img1259121657463.jpg]
This pdf about the Nismo pivot balls shows the short to be 41mm long vs the long ones 54mm:
http://www.nismo.co.jp/en/products/c…/pdf/pivot.pdf
