Forums/Z31P/z31-performance-upgrade-forums driveline-aa/Motul 300
Imported from Z31Performance.com Forums{{#if:300zxturboftw| — original post by 300zxturboftw}}{{#if:2013-04-11 14:44:09|, posted 2013-04-11 14:44:09}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/21224-motul-300.html|
300zxturboftw: (2013-04-11 14:44:09)
Have you guys used motul 300 75-90 in our gear boxes? Is it safe?
Careless: (2013-04-11 14:57:49)
No, not compatible… The only two GL4 Motul compatible gear oils with the correct viscosity ranges are MotylGear 75w90 and Gearbox 80w90.
I used the Motyl 75w90 in my trans before the last swap, as well as in my LSD with an additive, since the only place around my friends neighbourhood was having a Z/G car show and was selling it for a good price while I was doing my trans/diff swap.
It was fine. Shifted nice. Clutch locked up in the diff as it should have. No metal particles in the trans oil after the last change.
Snce I had to drop that trans again, I put 1 qt of Redline MT90 and just under 1 qt of AMSOIL Manual Transaxle lube because it's all I had.
Both are strict GL-4's. AMSoil is easier to get.
300zxturboftw: (2013-04-11 15:38:11)
http://www.2wheelpros.com/motul-gear…FRRfnAodMVsAKA
This?
API: GL-4/GL-5 compatible.
Careless: (2013-04-11 15:55:17)
ohhhh nvm. I was looking at the Gear 300 LS.
I should check my garage to see if I actually have the Gear 300. brb.
edit:
MotylGear Technosynthese 75w90 is the one I used. it's a GL-4/GL-5. I used it in the Diff and the Trans. Still got almost a full quart.
300zxturboftw: (2013-04-11 16:00:49)
Yeah im using 300 75-90 in the subaru right now and wanted to make sure its safe for teh z. both have brass bushings. Subie gearbox is weird.
Z shifted like buttery nips but i drained out the redline and had a decent amount of shrappnel. Want to switch it up to motul because their products are awesome.
frostvectron: (2013-04-11 17:58:36)
http://z31performance.com/showthread…-can-be-a-pain
So I am guessing Motul Gear 300 is good?
Careless: (2013-04-11 18:02:25)
if it had shrappnel, i doubt it's because of the redline. chek yer chit, bro. something might be ready to go poo.
300zxturboftw: (2013-04-11 18:24:50)
Was normal shrap, just one very very long thin metal strand (about 2 inches long). Gearbox is solid though, everything I put to it it takes.
