Forums/Z31P/z31-performance-upgrade-forums driveline-aa/LSD CV Axle
Imported from Z31Performance.com Forums{{#if:pokeyquick| — original post by pokeyquick}}{{#if:2014-03-18 21:39:39|, posted 2014-03-18 21:39:39}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/23471-lsd-cv-axle.html|
pokeyquick: (2014-03-18 21:39:39)
Hello all,
I wanted to know if I replaced my na differential and cv axles with an LSD from a 88 turbo will the axle flanges match up?
NissanEgg: (2014-03-18 21:51:07)
If it's a CLSD, then the axles will pop right in. If it's a VLSD from a Shiro, you will need the VLSD axles.
pokeyquick: (2014-03-18 22:00:47)
Will the axles match bolt patterns with my na control arm axle flanges?
frostvectron: (2014-03-18 22:33:50)
On the wheel side NA axle flange is 3x2 pattern and turbo is 4-bolt pattern. On the diff side both axles (turbo and NA) will plug in fine between open diff and CLSD (but not VLSD).
