Forums/Z31P/z31-performance-upgrade-forums driveline-aa/Help with my clutch
Imported from Z31Performance.com Forums{{#if:domingo| — original post by domingo}}{{#if:2017-02-19 22:46:19|, posted 2017-02-19 22:46:19}}{{#if:9| · 9 post{{#ifeq:9|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/534419-help-with-my-clutch.html|
domingo: (2017-02-19 22:46:19)
somebody can help me, clutch that lackas a lot Nm, I have a DXD 350z and it does not work
NissanXRMA: (2017-02-19 22:56:42)
Will likely need more information… Is the clutch new? Did you check the free-play of the clutch pedal? Can you verify the clutch was installed properly (disc not backwards) ?
domingo: (2017-02-20 21:43:44)
Hahahaha, seriously that there are people who put the album upside down ???, everything is new, buy the ferrometal disc first, but when I rise from psi it holds up
domingo: (2017-02-20 22:00:45)
Someone placed a clutch of rb26 in a z31?
NissanXRMA: (2017-02-22 12:28:29)
I'm lost on your phrasing.
domingo: (2017-02-22 22:52:54)
Sorry, I use the google translator, I do not speak English.
NissanXRMA: (2017-02-23 04:18:00)
Check the freeplay per the FSM. If you get under the car, and cannot wiggle the slave cylinder pin that pushes on the clutch fork, your clutch is partially disengaged.
domingo: (2017-02-23 21:54:13)
If it is unlocked
domingo: (2017-02-23 22:09:41)
I am thinking of buying this, OS Giken TS2B Twin Plate Clutch Kit
Someone tried it?
