Forums/Z31P/z31-performance-upgrade-forums driveline-aa/Found some limits (broken half shaft)
Imported from Z31Performance.com Forums{{#if:z31t| — original post by z31t}}{{#if:2010-05-19 13:50:58|, posted 2010-05-19 13:50:58}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/10602-found-some-limits-broken-half-shaft.html|
z31t: (2010-05-19 13:50:58)
3 Passes on the new setup at zmax dragway with a best of 11.90 and the clutch slipping.
[http://[video=youtube_share;iwervpX89_E http://www.youtube.com/watch?v=iwervpX89_E[/video]] [archived image: yt_logo_rgb_light.png]]
Careless: (2010-05-19 14:54:18)
Re: Found some limits
limits of what clutch brand / stage
DeleriousZ: (2010-05-19 14:55:28)
hahaha doh!!
z31t: (2010-05-19 15:23:42)
I was referring to the video of the broken axle and stub.
Robyr: (2010-05-19 15:27:50)
Hehehe. Too bad about the axle, but its cool as shit that you've done it at all.
SATAN: (2010-05-19 18:47:44)
I was waiting for you to post these.
Do you have a vid of the run that broke them? Or… LOL… at least the start of the run?
z-flash: (2010-05-20 00:23:33)
Ouch! Are these n/a halfshafts (tripod) or the turbo halfshafts (birfield)?
They look like the n/a's, I am impressed they lasted this long if they are indeed n/a's.
z31t: (2010-05-20 01:48:29)
I think there is a video of the run but the car litterally never moved, from inside the car it sounded likke it popped out of gear. That axle is an NA but I've broken a turbo as well and all I had was an NA to replace it so I swapped flanges. I'm pretty sure the axle went and then the stub right after but the track was super sticky as you can see.
