Forums/Z31P/z31-performance-upgrade-forums driveline-aa/FS5W71C Compatibility
Imported from Z31Performance.com Forums{{#if:Z31Wrencher| — original post by Z31Wrencher}}{{#if:2012-10-30 21:24:50|, posted 2012-10-30 21:24:50}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/19675-fs5w71c-compatibility.html|
Z31Wrencher: (2012-10-30 21:24:50)
My transmission, a 1987 FS5W71C, decided to blow up, so I have to get a new one. I found a 1985 FS5W71C at a local salvage yard, but I was told it wouldn't work in my Z (1987 NA). I know the 1984-1989 FS5W71C were the same internally, but some people said they had trouble swapping 1987+ transmissions into 1984-1986 cars. Half of the people I ask say I can do the swap without tapping new holes for the crossmember, half say otherwise. So before I spend the money I just want to get another opinion. Can I swap an 85 FS5W71C into my 87 NA? Thanks.
michaelp: (2012-10-30 22:26:50)
The half who say you can't are retarded. They're the same transmission externally..mount and all.
Guardian: (2012-11-09 11:53:34)
+1 yeah it shouldn't matter. But I will add, when I ordered my synchro kit from drivetrain.com, they had the 84-86 years separated from the 87-89 years. :-?
862sik: (2012-11-10 10:06:55)
Yea it will work 100%. The only thing down there that's different from the years is the driveshaft flange to the differential.
michaelp: (2012-11-10 14:39:15)
Yep, there are some differences internally with the syncros but nothing external and nothing that affects if it can/cant be used in any year Z31.
