Forums/Z31P/z31-performance-upgrade-forums driveline-aa/DXD Clutch Confusion
Imported from Z31Performance.com Forums{{#if:harwood909| — original post by harwood909}}{{#if:2014-06-07 16:08:41|, posted 2014-06-07 16:08:41}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/23846-dxd-clutch-confusion.html|
harwood909: (2014-06-07 16:08:41)
Maybe I'm the only one, maybe I'm not, but here is my situation. I'm looking through Acadiana for a clutch and I'm a bit confused as to which one really suits my power goals and purpose of my car. Power goal is right around 420 Ft/lbs and usage will be about 80% romping through town and 20% autocross and lapping days. There are a few clutches here that state they will hold that power just fine but I get lost when it comes to the different disc compounds used on each clutch. I would really like to hear from others that are using these clutch kits.
G-E: (2014-06-07 22:24:42)
Why don't you call dave @ sbc directly and see what he recommends?
Although I suspect you should be looking at a stage 3 or 4 with kevlar disc, since you're probably not interested in maximum engagement on/off like you'd have with a 6-puck race disc…
harwood909: (2014-06-08 16:31:26)
That sounds like a good idea. I've heard his name mentioned in another thread, what is his role at sbc?
