Forums/Z31P/z31-performance-upgrade-forums driveline-aa/Cruise control switch on clutch pedal
Imported from Z31Performance.com Forums{{#if:ozzyrulez| — original post by ozzyrulez}}{{#if:2015-06-06 22:43:22|, posted 2015-06-06 22:43:22}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/25081-cruise-control-switch-on-clutch-pedal.html|
ozzyrulez: (2015-06-06 22:43:22)
So I'm about to hook up launch control on my MS3 system. I was going to use the neutral safety switch but it is at the very end of the clutch pedal which isn't really ideal for flat shifting as I don't want to have to push the pedal that far. So I was eyeballing the cruise cancel switch as it is at the top of the pedal throw. The thing is, Megasquirt uses ground to enable launch control. So I would need that switch to turn ground on when the pedal is pressed and off when released. Does anyone know if pushing the pedal completes the circuit or kills it? I would pull the switch and see but it is raining its ass off out there so I figure I can gather a little intel first then tackle it.
les_joey_paul: (2015-06-08 05:17:48)
Pretty sure it kills it.
ozzyrulez: (2015-06-08 15:09:25)
Yeah it kills the circuit. After it stopped raining I went out and figured it out. That's alright I used the neutral safety switch. It works nicely, I just need to reteach myself to kick the pedal the whole way down while shifting to get flat shifts. Launch control is as useless as I expected it to be on street tires. It is fun as hell though.
