Forums/Z31P/z31-performance-upgrade-forums driveline-aa/CLSD 6 clutch mod
Imported from Z31Performance.com Forums{{#if:Pete87T| — original post by Pete87T}}{{#if:2012-12-11 05:29:26|, posted 2012-12-11 05:29:26}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/20080-clsd-6-clutch-mod.html|
Pete87T: (2012-12-11 05:29:26)
I'm looking into this while I have my diff apart, details are here:
http://www.kamikazeracing.org/dl/ZTech/ … ebuild.pdf
It eliminates the spacers and replaces them with two extra clutches on each side; topped off with shimming it to the exact break away torque desired.
Sounds perfect…
The factory set up has a disk on each side of the clutch. This way when the LSD slips, the clutches are only rubbing up against the friction plates.
If two clutches are added per side, the outermost clutch (friction disk) will be using the spring plate as a friction plate, and the inner most clutch
will be using the center section (pressure ring) as a friction plate.
The only reason this concerns me is that now there are surfaces in the diff that were not intended for friction acting as friction plates.
The other half of me says screw it…you want it to last forever???
Opinions?
aceman: (2012-12-11 06:43:16)
Bought a diff one time that had a pepsi can cut up for the spacers.
yuck pepsi.
G-E: (2012-12-11 06:46:42)
You can buy any number of new lsd's for 900-1200$ and used for less, I'd say do it if you can do it cheaply…
DeleriousZ: (2012-12-11 14:15:21)
I've done this, as well as quite a few people over at hybridz.org. I haven't heard of it causing any issues, but you might want to go search around there, as they probably have more than 50km on their car since installing it lol.
michaelp: (2012-12-11 22:12:56)
I only did 4 clutches…but I put thousands of miles on mine, its good. Locks up nice…cars way more predictable now too…but I never drove it with the 2-clutch setup because the car was open diff before and I rebuilt my CLSD before it went in. Would have just gone KaaZ or similar had I not gotten the CLSD and a 30A for $300.
Pete87T: (2012-12-11 23:01:20)
just out of curiousity, if you only used 4 instead of 6, what did you use to fill in the space? mill down the spacer by 1.75mm?
Funny thing - 3 of my friction plates are 1.75 and one is 1.85mm....no big deal, thicker plate = one less shim.
MADMIKE: (2012-12-11 23:26:37)
My Nismo GT Pro has 20 discs I believe. They can be had used for pretty short change.
michaelp: (2012-12-12 00:07:18)
[quote]Pete87T wrote:
I cut the tabs off a couple of the stock clutches and used them as spacers....because they were half the size of the stock spacers which means if I'm adding 2 more clutches…the spacer needs to be about half the size. Without the tabs they won't engage in anything so they're just spacers at that point. Everything checked out fine and it works great.
