Forums/Z31P/z31-performance-upgrade-forums driveline-aa/Automatic Bellhousing
Imported from Z31Performance.com Forums{{#if:gorekill| — original post by gorekill}}{{#if:2013-05-13 15:57:02|, posted 2013-05-13 15:57:02}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/21537-automatic-bellhousing.html|
gorekill: (2013-05-13 15:57:02)
Heya all, getting another Z soon that is automatic and I want to know if the bellhousing for the automatic is the same as the 5-speed? Basiclaly I want to know if my auto bellhousing can bolt up to my Z32 transmission like the other 5-speed Z31 transmissions do?
Augustus Maximus: (2013-05-13 18:09:13)
The Z31, Pathy, Nissan, 30A bolts up to your Z32 tranny. Auto bellhousing is not going to work. Here's a question for you. Where would you put the slave cylinder, clutch fork, pivot ball etc. Do tell[archived image: confused.png].
gorekill: (2013-05-13 19:47:42)
That's why I asked. I know the VG33 and VG30 are the same motors with the same pre-drilled holes, just the accessories are in different places, etc. That's why I was asking. And I also thought that the Z32 wasn't a direct bolt up, due to the starter motor; that you needed to mount the back end of the transmission to a Z31 bellhousing.
