Forums/Z31P/z31-performance-upgrade-forums driveline-aa/Alternative to fill plug?
Imported from Z31Performance.com Forums{{#if:jaqattack02| — original post by jaqattack02}}{{#if:2012-11-12 03:04:43|, posted 2012-11-12 03:04:43}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/19804-alternative-to-fill-plug.html|
jaqattack02: (2012-11-12 03:04:43)
The fill plug in my 71C is seized. I've tried heat and penetrating oil but I can't get it to budge. Is there an alternative I can use to fill it to the correct level? I filled it through the shifter hole before installing the shifter, but it had a small leak so I wanted to top it off and found the plug was stuck. Anyone have any advice?
862sik: (2012-11-12 03:11:49)
are you sure you used the right tool?
[archived image: big-breaker-bar-mr1333241059.jpg]
84Zed31: (2012-11-12 03:16:56)
I've taken the shifter off and poured the fluid through there, as long as you know the capacity. And on my t5 I forced a smaller socket onto the bolt and now it's there for life, but that's because it was rounded off.
300zxturboftw: (2012-11-12 06:02:32)
I've always drained trans through drain plug and refilled through shifter with FSM required capacity. One snap ring for me is easier than trying to find a good angle to crank that fill plug loose if I don't have the car jacked way up.
jaqattack02: (2012-11-12 13:53:24)
I know I could drain and refill, but I was trying to avoid having to buy another 2 quarts of Redline. The fluid in it is brand new as I just filled it less than a month ago and the car hasn't been driven since then. I guess I could try draining it into a clean container and re-using what's in it.
I forgot to add, it's also not as easy as a snap ring. I have an aftermarket shifter in it so I'll have to unbolt the whole shifter assembly from the transmission.
862sik: (2012-11-14 04:44:54)
so if the fluid is new and only a month old, why change it?
As for your shifter, drill and tap in a fill plug
jaqattack02: (2012-11-14 14:00:50)
I don't want to change it, i want to top it off. It was leaking and I don't know how much fluid is in it now.
That's not a bad idea on the fill plug though. I'll have to look into that if I pull the shifter again.
