Forums/Z31P/z31-performance-upgrade-forums driveline-aa/87 NA Differential
Imported from Z31Performance.com Forums{{#if:pokeyquick| — original post by pokeyquick}}{{#if:2012-08-29 00:29:42|, posted 2012-08-29 00:29:42}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/19088-87-na-differential.html|
pokeyquick: (2012-08-29 00:29:42)
Who rebuilds NA diff. in the NC area? Mine is very noisy and I believe that the rear clunk that I'm hearing is coming from it. I have replaced all of the bushing, rear diff mount, and drive shaft u joints. I can hear the clunk when I put it in gear and when I give it gas at low speed or when I pat the gas at low speed but in a higher gear. It sounds like a clanking noise or a metal to metal clunk!!!
DMANN: (2012-08-29 01:14:15)
If you replaced the u- joints in the driveshaft you can rebuild the diff yourself.
If not get another one it will be cheaper.
