Forums/Z31P/z31-performance-upgrade-forums driveline-aa/85 NA CLSD Swap?
Imported from Z31Performance.com Forums{{#if:Brootal Koopa| — original post by Brootal Koopa}}{{#if:2012-08-16 01:30:50|, posted 2012-08-16 01:30:50}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/18949-85-na-clsd-swap.html|
Brootal Koopa: (2012-08-16 01:30:50)
Picked up a CLSD from an 87T. Want to put it into my 85 NA. Just curious if I need anything else or will it just bolt right up? Keep seeing info about new half shafts and companion flanges but no idea if I will need them or not.
84Zed31: (2012-08-16 03:10:40)
It'll swap right in, no need for new axles. You just need to swap your companion flange on your old diff to the clsd.
shromy: (2012-08-16 05:13:46)
As well as keep his original shims on each side, swap ring gear, and add an lsd additive.
