Forums/Z31P/z31-performance-upgrade-forums driveline-aa/71C rebuild questions
Imported from Z31Performance.com Forums{{#if:trogdor1138| — original post by trogdor1138}}{{#if:2013-05-17 00:56:31|, posted 2013-05-17 00:56:31}}{{#if:1| · 1 post{{#ifeq:1|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/21569-71c-rebuild-questions.html|
trogdor1138: (2013-05-17 00:56:31)
Rebuilding a 71C from a 86NA for transplant into my 86T over the next week. Just a few questions:
- Does anyone know what the neutral switch on the T5 actually does? Not the clutch pedal switch, but the switch actually in the transmission? I know my clutch pedal switch works since it disengages cruise, but what does the neutral switch add further? I found this thread, but it didn't seem to arrive at an answer: http://z31performance.com/showthread…neutral+switch
- What, if anything, are those of you who have rebuilt transmissions using for snap rings and shims? There are a few key points where the FSM calls for checking clearances and then selecting an appropriate shim or snap ring. I rebuilt a 4-speed on my 71 240Z and didn't check clearances, and it worked great and survived a high-compression bored-out 280Z engine swap. Any experience either way?
- I also snagged the driveshaft and transmission mount. I think this should cover any differences?
- Any other snags or gotchas to be prepared for?
