Forums/Z31P/z31-performance-upgrade-forums driveline-aa/430-11A alternatives?
Imported from Z31Performance.com Forums{{#if:flatfoot| — original post by flatfoot}}{{#if:2014-04-10 05:21:41|, posted 2014-04-10 05:21:41}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/23609-430-11a-alternatives.html|
flatfoot: (2014-04-10 05:21:41)
Having just blown out both brand new 430-11A U-joints tonight on the way home from work does anybody have a better alternative??
I'm going to call around about having a custom driveshaft built tomorrow, but I'd really like to find something cheaper for the short term.
mcx: (2014-04-10 10:38:19)
I was curious how many miles you put on those joints…I was going to purchase one to fix a clunk that has developed recently.
flatfoot: (2014-04-10 11:24:40)
Under 400 on my 86 turbo.
I just put them on Sunday to replace an original factory set.
This isn't my first set I've blown. Last year I blew a one in a parking garage so I was lucky and found somebody parting out a car here at that time and snagged a whole driveshaft from them which I wore out doing 150+ miles a day on the daily driver.
mcx: (2014-04-10 12:11:14)
disappointing…inferior product[Rockford] or is your yoke egging out and excessive clearance, perhaps??
G-E: (2014-04-10 12:12:27)
I hate to say it, but I don't think the u-joints are your problem, or at least not the cause… I'd be checking your trans mount, engine mounts, subframe bushings and diff mount very thoroughly
I suspect you're putting too much stress on them at awkward angles, which then leads to failure after so many instances
mcx: (2014-04-10 12:33:37)
I agree, with mine anyway…I just upgraded to poly rear cross member bushings, filled diff mount[windowweld] and new center driveshaft support bushing[200sx] and now the u joint started clinking....it aint happy with returning parts to the correct positioning, I suppose.
G-E: (2014-04-10 13:47:50)
I've found the trans mount is the most overlooked one of the lot, and the one that allows the trans to flop around like a dying fish
