Forums/Z31P/z31-performance-upgrade-forums driveline-aa/(higher) clutch friction point
Imported from Z31Performance.com Forums{{#if:restore| — original post by restore}}{{#if:2010-06-08 15:06:42|, posted 2010-06-08 15:06:42}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/driveline-aa/10826-higher-clutch-friction-point.html|
restore: (2010-06-08 15:06:42)
After a weekend of hell-ish traffic driving in NYC, i noticed that my clutch friction point is a bit higher than normal.
I have yet to bleed my system (it has been roughly 14 months since the last time), so I am hoping that this will be the fix…
Does anyone else have experience with a a "higher" clutch friction point that a bleed seemed to fix?
(I am trying to avoid an entire clutch replacement, budget issues)
thanks..!
Grr: (2010-06-08 15:10:57)
mine has done that twice and a bleed has helped both times. I may have a master cyl that is getting weak and leaking by causing it
restore: (2010-06-08 15:46:23)
yea i had a leak too, so i replaced the master+slave cylinder last year. but in that instance, i had ZERO clutch pressure lol
restore: (2010-06-09 04:36:59)
neone else have a similar problem that was resolved by fresh clutch (brake) fluid and a bleed?
Dave@SBC: (2010-06-09 16:55:00)
If you're speaking of the location of the engagement of the clutch. There's also the possibilty that you wore the clutch down a bit. As a clutch wears out, the point of engagement gets higher on the pedal.
DeleriousZ: (2010-06-09 17:12:47)
If what dave is saying is the case, then you can adjust the engagement point/clutch pedal position underneath the dash right near the top of the pedal arm.
Dave@SBC: (2010-06-09 20:11:55)
werd!
