Forums/Z31P/z31-performance-upgrade-forums cosmetic-interior-exterior/plz confirm switch temp
Imported from Z31Performance.com Forums{{#if:adroitcaptor| — original post by adroitcaptor}}{{#if:2013-09-14 22:37:19|, posted 2013-09-14 22:37:19}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/cosmetic-interior-exterior/22599-plz-confirm-switch-temp.html|
adroitcaptor: (2013-09-14 22:37:19)
I am trying to make a dual temp triggered, tripple relay setup out of the maxima fans. Can somone confirm the stock VG coolant temp switch at 200 on / 190 off [please]? Sentra switch will turn on 1 fan, stock VG switch will turn on both. Thx!
michaelp: (2013-09-15 02:42:03)
stock z31 is 212
Operating temp should be ~170-180. Both are too high.
adroitcaptor: (2013-09-15 06:05:39)
What to use then bro?
Not that corporate action is self justifying, but I thought the 190 senta switch was what everyone was using?
Should I get a Tstat for 170 then?
G-E: (2013-09-15 09:48:38)
Having a fan come on at 180ish is ideal if your t-stat is 165-170, you don't need it to kick on and off constantly just above the t-stat temp..
adroitcaptor: (2013-09-15 12:13:06)
What temp switch should I use?
adroitcaptor: (2013-09-16 14:42:18)
Anyone?
michaelp: (2013-09-16 16:37:45)
The Sentra switch would work....~180 would be preferable but 190 would still cool the car.
